Crank no start after replacing head gasket valve cover
I really need help. I have a 97 BMW z3. I had recently replaced my head gasket valve cover. An after I got a crank no-start situation. I replace the fuel pump/camshaft position sense/Rear 02 senor/spark plug and ignition coils/fuel filter/replaced the gas cap/Replaced fuel pump relay/ It has a new battery. It still will not start.
Here are my codes: P0340 P0420 P1188 P0442 P0170 Thanks, |
2. Is it getting fuel? 3. How is the compression? 4. Is the timing correct?
1986 928S 32 valve engine All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires. Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster |
