-   BMW Z3/Z4 Forum (http://forums.pelicanparts.com/bmw-z3-z4-forum/)
-   -   Z 3 airconditioning refrigerant refilling (http://forums.pelicanparts.com/bmw-z3-z4-forum/1066736-z-3-airconditioning-refrigerant-refilling.html)
Biggles123 07-08-2020 01:05 PM
Any advice on using refrigerant refilling kits , or is this a specialist job?
Biggles
harborman 07-09-2020 06:20 AM
I have always gone to a shop that does it. You need gauges and know how to use them and the right amount of refrigerant to put in. You may need to evacuate the system first and then put in the new.
buggerlugs 07-21-2020 11:52 AM
Hi
I had my A/C checked by an A/C shop . they found a leak .changed an O ring and refilled it with a LOT of refrigerant. The techie said that the condenser fan was not working , but they were not available from our local friendly BMW dealer Before I invest in some thing at unobtainiaum price
Do I really need a fan ?Where can I find a sketch of the A/C loop, and a wiring diagram ?
There's probably a lot of electrcal reasons why the fan does not run !
harborman 07-23-2020 06:36 AM
Originally Posted by buggerlugs (Post 10955434)
Hi
Check ebay, there are some listed which might work.
buggerlugs 07-23-2020 09:26 PM
Z 3 Air conditioning continued
Checked out the electrics , relays and fuses , except fuse 48 a 40 amp fuse in the auxiliary fuse box . Where is this fuse box?
There is one last electrical check at the connector to the fan motor . I think this is the hefty connector on the right hand side of the radiator . This has heavy wires running through it , How much power does the fan draw ??
If I need to replace the fan ,I will have to strip out a lot of the front end to gain access to the fastenings . Has any one done this ?? Any suggestions ??
Thanks in advance
buggerlugs
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
