M44 Z3 or 318is suffocate momentarily during drive
Hi all
I am driving a 1997/8 M44 (Z3 or 318is). It is 1997 elsewhere but 1998 in South Africa. It somewhat suffocates during drive. It does not lose power as such because it continue moving at constant speed Even when pressing gas (accelerator), it does nothing for a while, then suddenly moves. During the suffocation, the l/100km guage (fuel consumption guage) stays at about 10 or 11 while am pressing gas hard...then suddenly perform again. I changed fuel filter, fuel pump, throttle body cleaned and airflow meter cleaned. Cylinder head was recently done as well, rather replaced with a used one as my old was bending valves each time after reconditioning. I also changed the lambda sensor as well. Lastly, the idle is not as smooth. It feels like when it feed more fuel/gas. But the mileage is somewhat reasonable at average on 9 liters per 100km inst city or 7-8 liters per 100km on high way I suspect maybe air leak but failing to locate it. Any ideas on what can I check. Thanks in advance. Dido Spear |
I wrote here and replying myself again.
The problem was "knock sensor". Replaced it, though with old one but problem solved. No third party spares supply and BMW promise delivery in 6-7 weeks (I guess South Africa is too far). But I had one from.old engine that I junked few years back. Problem solved. |
1986 928S 32 valve engine All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires. Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster |
Thread Tools | |
Rate This Thread | |
