2000 Z3 2.3 reassemble
Dad recently passed away and now I have a Z3 that has been sitting for 3 years to reassemble, nothing labeled to reconnect. Working to fix it for his great grandson. I have spent countless hours looking at videos and diagrams trying to figure-out all the hoses and connections hanging loose. Hoses are the worst because every one I touch one it is rotten and crumples.
Could someone look at these images and tell me where the connections go? Intake 1 - what hose connects here ![]() Intake 2 - where do these two hoses go ![]() Intake 3 - where does this go ![]() Intake 4 - Where does this hose connected to the blue line running towards transmission go ![]() Intake 5 - What hose connects to this sensor ![]() Also is there a way to tell which fuel line is the supply and return and which connection of the fuel rail connections they go to. Thanks for your help! |
Maybe your best bet is to get a shop manual.
1986 928S 32 valve engine All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires. Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster |
Check into the pelican parts technical articles at the top of this page. Start with r&r the intake manifold. They do a really good job, along with pictures, of explaining removal and replacement of parts. Looks to me like most of what you pictured is under/behind the intake manifold. As for #1, that might be a rubber cap (7mm I think). I'm in the process of replacing my head gasket (2001 Z3) and those hoses all look familiar.
Good luck. |
As Siegrw stated, our "How To" Tech Articles also you may want to pick up a Bentley Service manual for more technical breakdowns of working on your car.
Tags |
2000 z3 , connections , vacuum hoses |
