Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW Z3/Z4 Forum
Tapping sound from cyn 6
I have a 2000 z3 2.8 with 138k miles. I have replaced all the hydraulic lifters and still there
When cold noise is very minimum but as the engine warms up it gets worse. Did a compression test and cylinder 6 is at 160 and the rest run from 210 to 240.
Occasionally I will get a code cylinder 6 misfire but no roughness on the engine is felt.
Any thoughts
Thanks Larry
Old 01-04-2022, 03:41 AM
harborman's Avatar
Well, sounds like you pined it down to Cyl 6. Bent valve, broken spring?
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 01-06-2022, 11:51 AM
