Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW Z3/Z4 Forum
"A" "A" is offline
el Cheapo
"A"'s Avatar
Z3 Coupe 3.0 engine with Dinan?
I have no clue what I'm getting myself into, but does a Z3 Coupe make a decent daily driver?
Does Dinan tuned engine make significant difference?
When in doubt, throttle out.
Brakes, who needs them; they only slow you down.
Old 07-31-2021, 03:55 PM
"A" "A" is offline
el Cheapo
"A"'s Avatar
Previous owner had suspension lowered, causing rear wheel tire to camber enough to result in uneven wear in rear tires.
Can anyone suggest a online source for struts & springs to put this car back to stock ride height for a daily driver?
Also the PO had put on tacky, fake M3 logo onto the car, I've removed the logos, but the residue adhesives (2-3mm thick) are still on the frame.
I tried blow dryer, Goo-Gone, very time consuming.. any better ways to remove these adhesives?
Old 08-02-2022, 06:10 AM
Administrator
Matt at Pelican Parts's Avatar
Beatiful Z3 coupe! The M54 3.0L Engine is very reliable if maintained properly. As far as returning the car to stock ride height, I would suggesting running OE components.
We carry Bilstein for the shocks and struts:
Bilstein Rear Shocks Z3 Coupe
Bilstein Front Struts Z3 Coupe (Left)
Bilstein Front Struts Z3 Coupe (Right)
You can also pick up this compete kit which has all the necessary hardware and parts for refreshing your suspension.
Complete Kit (Stage 2)
As far as OE replacement springs goes, we carry Lesjofors:
Front Spring Z3 Coupe (Manual)
Rear Spring Z3 Coupe
Hope this helps!
-Matt
Old 08-02-2022, 01:25 PM
"A" "A" is offline
el Cheapo
"A"'s Avatar
Does it make any difference if this car has auto tranny?
Old 08-02-2022, 05:46 PM
harborman's Avatar
Daily driver? In summer, but not in snow and ice if you live up north. At lease I would not drive mine in those conditions.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 08-05-2022, 05:52 AM
"A" "A" is offline
el Cheapo
"A"'s Avatar
This past Sunday meet with the Coupe Cartel:
Old 09-13-2022, 10:49 AM
Administrator
Awesome pictures! That has got to be the most "clownshoes" I've ever seen in one place!
-Matt
Old 09-16-2022, 05:42 PM
"A" "A" is offline
el Cheapo
"A"'s Avatar
Good to see so many still operational & in circulation.
Someone with artistic talent & A/V club connection even made a video of the gathering.
https://youtu.be/CJsXkhgTlUU
Old 09-18-2022, 08:08 AM
"A" "A" is offline
el Cheapo
"A"'s Avatar
Finally, a great day to ride & drive.
Car is a bit dirty, but still very entertaining to drive.
Old 04-23-2024, 10:38 AM
Administrator
Good to see you're still posting updates! I love a good clownshoe!
Old 04-25-2024, 03:09 PM
"A" "A" is offline
el Cheapo
"A"'s Avatar
Clown shoes gathering last weekend.
https://youtu.be/GpLYTqL7TBw?si=ICaYJPfUm2ZIQDiJ
Old 05-09-2024, 07:30 AM
