Go Back   Pelican Parts Technical BBS > 2- BMW Forums > BMW Technical Forums > BMW Z3/Z4 Forum
2003 z4 airbag light turned on
over the weekend i took the car on a fly fishing trip, unfortunately a 1 mile stretch of road was dirt, but it was mostly smooth with little bumpy grooves in the road. my airbag light has turned on and at one time it would not stop beeping for 20 minutes. now when i turn the key the airbag light just stays on.
what do i need to check and where? how do i reset the light? any ideas anyone?
i'm a z3 and z4 owner if you see my other postings. why? its called a midlife crisis to let me know i still got it with the chicks.
Old 11-12-2009, 05:38 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Jeron's Avatar
Probably the passenger seat sensor mat. Reset the light and see if it comes back. You need a Peake or (another brand I cant remember) reset tool.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 11-17-2009, 10:49 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
i bought the peake tool with connector, about 185 bucks. and it showed there was no fault code. i tried to reset the light, but it did not turn off or flash or anything. any ideas?
Old 12-09-2009, 08:16 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
sudo apt-get purge 930
equality72521's Avatar
Not sure about your year but our 1999 Z3 has two different ports. One is the OBD2 ports on the right side of the center console and the other is a round one under the hood. Also, the round one takes two different tools. One to reset the oil light and another to reset the airbag.
--clutch-monkey
Old 12-17-2009, 10:04 AM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
where can i get those tools
Old 12-21-2009, 11:40 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
shogun's Avatar
I have the SIR3 for sale, see here
resets SRS/airbag/oil/inspection and annual inspection
Want to buy Zymexx SIR3 reset tool for Airbag light
that is for the 20-pin round diagnosis plug in the engine room.
Check your engine room for the 20-pin plug, some cars still have over some years the 20-pin plug and the newer OBD II square plug. Reset from the 20-pin plug.
On a 1999 model the Peake tool basically should work, their website says for most BMW models from 1994. My tool works on most BMW from 1987! -
SHOGUN'S TRICKS AND TIPS FOR THE SEVEN SERIES
http://twrite.org/shogunnew/topmenu.html
Old 12-23-2009, 08:53 PM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
R5/FCX3-U
BMW Reset Tool, BMW Scan Tool, Peake Research Inspection & Oil Service Reset Tool, Fault Code Scan Tool
--clutch-monkey
Old 12-26-2009, 08:23 PM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
shogun's Avatar
Originally Posted by equality72521 View Post
R5/FCX3-U
he already has a Peake tool, but it does not work, read his post above!
i
Old 12-27-2009, 12:49 AM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
i
He didn't say which version of the tool he has, he simply says "the Peake tool". If he's using the R5/FCX3 on a 2001 or newer it won't work whereas the 5/FCX3-U will. Also, if his car is an M or newer than 2000 and he's using the R5/FCX3-16 he'll need the 20 pin FCX 3 that plugs in under the hood.
Part Number: R5/FCX3
Application: BMW 1987-2000
Part Number: R5/FCX3-U
Application: BMW 1987-2007
Part Number: R5/FCX3-16
Application: BMW 2001-2007
IMPORTANT: For 2001 740i, 740iL, 2000-2002 Z3/MCoupe/MRoadster, 2001-2003 X5, If your BMW has the 20 pin connector under the hood, you need to Use FCX 3
--clutch-monkey
Old 12-27-2009, 05:31 AM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
shogun's Avatar
he wants to reset the Airbag/SRS light, he does not need a fault code/reset tool.
BMW Reset Tool List
R5/FCX3 Fault Code BMW Reset Tool (1987-2000 BMWs)
R5/FCX3-16 Fault Code BMW Reset Tool (2001-2006 BMWs)
R5/FCX3-U (Combo) Fault Code BMW Reset Tool (1987-2006 BMWs)
R5B & R5A Oil Service & Inspection BMW Reset Tool
BMW Airbag Tool
R5/SRS Airbag (SRS) Scan / Reset Tool (1994-2000 BMWs)
R5/SRS-16 Airbag (SRS) Scan / Reset Tool (2001-2003 BMWs)
R5/SRS-U Airbag (SRS) Scan / Reset Tool (1994-2003 BMWs)
Old 12-27-2009, 03:18 PM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
,MBT Karani Shoes
It is really hard to locate that which MBT shoes are one of the most advantageous offered how the two have numerous qualities. There are so an amazing offer of firms obtainable from the marketplace who mentioned which they are perfect but not any business compete the standard of hardwood flooring New York. offered that hardwood flooring ny has all all those MBT Sini Lux capabilities which a flooring set up firms should have. A stroll from the United Kingdom MBT Nama civiar of imitation curve pivot one concerning the beach. The only gets rugged uniform,www.mbtstop.com, flat ground. I believe that these MBT Shuguli GTX as well as a lady would like to comfort as well as you generally make an effort to women’s style.People who know mbt shoes, on mbt shoes lami pink certainly no stranger. MBT Tembea are going to be the 1st physiological MBT Bomoathat capabilities a optimistic result concerning the complete body. understand additional about MBT Moja Mid, research MBT shoes Reviews. MBT shoes developed by Swiss engineer Karl Muller, adopt Masai Barefoot Technology. MBT Nama individual the “world’s smallest gym” reputation,MBT Chapa GTX Shoes, which not just can sustain the body’s organically grown balance,Looking Forward to New Style MBT Bomoa Boots, but in add-on can stimulate and actual exercise the body’s supporting muscle method resulting within of various pro-body benefits. MBT Shuguli GTX is truly an acronym for Masai Barefoot Technology, the idea at the rear of their do it yourself proclaimed Anti-Shoe. The idea are going to be the actuality that MBT Tembea make you really feel like you are walking on an uneven surface area and that activates muscle tissue that are already left dormant in normal, flat soled shoes. MBT Bomoa also improve your posture as well as your gait and so are fabulous for walking all evening long. MBT Sini Lux aren’t just developed with that athletic shoe look, though. you will locate women’s MBT Imara and men’s MBT Fanaka GTX that are already wonderful for that workplace, which consists of sleek sandals and Mary Jane styles. They have also introduced multi-colored and enjoyment MBT sports actions two that are already wonderful for casual Friday and weekend walking. understand additional about MBT Moja Mid, research MBT shoes Reviews
Old 12-01-2010, 05:58 PM
  Pelican Parts Technical Article Directory    Reply With Quote #11 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
