-   BMW Z3/Z4 Forum (http://forums.pelicanparts.com/bmw-z3-z4-forum/)
-   -   99 Z3 newbie ABS and Engine Light (http://forums.pelicanparts.com/bmw-z3-z4-forum/582069-99-z3-newbie-abs-engine-light.html)
uksailmaker 12-25-2010 08:58 PM
20 plus BMW owner mostly 5 and 7 series
Just bought 99 coupe 6 months ago with 82k with no manual
wife has been driving so keep in mind this is her description of the problems if need more accurate description let me know and I will drive it for a day. Thanks
ABS light on but no braking problems
The triangle with circle light also on
When changing temp knob from cold to heat the engine shape light comes on but when switched back to cold and car turned off the engine shaped light goes off. no ..she is not blonde and does not say blinker is working, not working, working, not working.:D
any help is appreciated
BeyGon 12-29-2010 07:47 PM
I read your add in the for sale section and am looking for one, you mention that it might need new shocks in the rear, have you looked under the back to see if it has any problems with sub frame seperation, cracks or rivets pulled?
uksailmaker 11-06-2011 02:38 PM
Indy replaced to ABS sensor parts and labor $300 all is well
