Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW Z3/Z4 Forum
Z3 jumps out of 1st gear
Hi
My 1998 Z3 1.9 16 valve jumps out of 1st gear every now and again.
The car has only done 75000 miles.
It just does it when pulling away, it wont jump out as you drive and only does it perhaps once in every 100 miles.
I changed the oil and it was really black.
Is it likely to be a linkage problem or the gearbox its self.
Thanks in advance
Old 05-19-2011, 12:13 AM
Schneller's Avatar
It could be a linkage problem or also a transmission / rubber engine mount problem. When the trans & engine mounts age, they may sag or crack thus re-orienting the location of the transmission relative to the shifter linkage. Hence first gear may not be "in" all the way or the shift lever may actually be contacting the edge of the transmission tunnel through which it pokes. Similarly, worn selector shaft pivots & the rear shifter rubber mount may also be worn, preventing full engagement.
If these components are all in good condition, then I might suspect a gearbox problem.
Good Luck!
Schneller
Michael Morris
Schneller BMW Performance
26 Middle Rd Unit 1-2
Newbury, MA 01951 USA
978.465.2002
Mike Morris
Newbury, MA 01951
978.465.2002 www.machschnell.com
Old 05-20-2011, 11:01 AM
