Fan noise
Hi All
I recently bought a 99 z3. The only thing that irritates me is the access wind noise from the air fan. Can i replace the fan blade ore maybe replace it with a electrical fan |
Are we're talking about the engine cooling fan mounted on the end of the water pump? If so, it should only engage at idle. Once engine RPM increases, the fan clutch to which the fan blade is attached should slip & any fan noise should disappear. If the fan just spools up w/ engine RPM as you drive away, then the fan clutch may be faulty as it is engaged all the time.
Good Luck! ![]() Schneller Michael Morris Schneller BMW Performance 26 Middle Rd Unit 1-2 Newbury, MA 01951 USA 978.465.2002
Mike Morris ![]() Schneller BMW Performance 26 Middle Rd Unit 1-2 Newbury, MA 01951 978.465.2002 www.machschnell.com |
