Can't read abs or airbag fault codes
I've got an Autel MaxiDiag Pro (Autel) and for some reason I can scan the generic OBD 2 connection and the DME ( I can pull off live data and get generic fault codes), but I can't diagnose the ABS the Airbag or anything of that sort I'm trying to turn off a stuck traction control light (Triangle With ! in the center). So far all the fault codes are telling me is that I need to replace the 02 sensors... Is this a problem with the diagnostic tool? I just get an error saying that it can't communicate.
As far as I know, you need the factory reset equipment to turn off the SRS light. It's frustrating, I know.
Of course it might also help if I knew what kind of car this is for. |
97 z3 roadster
That's better than hearing the computers are going but it runs so that is out of the question. Hitting the ASC button does nothing and the light comes up directly on ignition whether or not I'm moving. |
| All times are GMT -8. The time now is 08:31 AM. |
