-   BMW Z3/Z4 Forum (http://forums.pelicanparts.com/bmw-z3-z4-forum/)
-   -   '97 Z3 2.8 starter problem (http://forums.pelicanparts.com/bmw-z3-z4-forum/740040-97-z3-2-8-starter-problem.html)
BillO 03-20-2013 08:29 AM
Just get a click from solenoid when trying to start. New battery. Verified solid, clean ground. Eliminated clutch pedal safety switch. Tried Bentley manual procedure for turning on lights, then trying to start -- lights do not go out, so doesn't look like short internal to starter. Looks like solenoid might be bad, but to get at it/starter, says need to remove intake manifold. Anyone know of any shortcuts on this or something else I should be looking at before I rip things apart? Also, is the BMW special tool 16 1 050 really necessary to release the clips that hold the fuel line to the rail, or is there something else that will work? Thanks.
quiet330 03-29-2013 08:25 AM
Have you completed the procedure?
I have the same problem on a 2000 Z3 M and it looks like that is the easiest way to remove the starter. It doesn't look like that it can be taken out from the bottom. I don't think you will need any special tools to remove the fuel line though.
