Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
In memory of Warren Hall (Early S Man), 1950 - 2008.
[Click for more details]
banner
Junior Member
DougZ3M's Avatar
Cool No dash lights
guys, I have a 98 M roadster and suddenly all the instrument lights are gone, fuses are OK, any suggestions?
Old 01-06-2003, 05:06 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
In the shop at Pelican
Jared at Pelican Parts's Avatar
Im confused, do the lights all go out when you turn on the headlights? I need a little more info here.
Old 01-07-2003, 08:31 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
CEO, Pelican Parts Inc.
Wayne at Pelican Parts's Avatar
Yes, more detail please. All of the indicator lights are off, or just the lights that luminate the gauges at night?
-Wayne
Wayne R. Dempsey, CEO, Pelican Parts Inc., and Author of:
101 Projects for Your BMW 3-Series101 Projects for Your Porsche 911How to Rebuild & Modify Porsche 911 Engines101 Projects for Your Porsche Boxster & Cayman
Coming in 2012:
• 101 Projects for Your MINI Cooper • 101 Projects for Your Porsche 996 / 997
Old 01-07-2003, 11:12 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
Junior Member
DougZ3M's Avatar
-Wayne
only the lights that iluminate the gauges at night, I remember that same day, I accidently pulled the shifter knob (the lights on it have not functioned since I bought the car) and tried to rearrange the stripped cables. I just disconnected the cables recently.
Old 01-21-2003, 03:48 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
Junior Member
DougZ3M's Avatar
-Wayne
Old 01-21-2003, 03:50 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
Did the car have a lighted shift knob? It's possible that the wires shorted out when you pulled th knob.
Old 01-23-2003, 09:26 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
Now available:  101 Projects for Your Porsche Boxster!
How exactly do you get the bulbs out of these knobs? I have one and i can't seem to get the insert off without damaging it.
Old 01-23-2003, 04:28 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #7 (permalink)
Junior Member
DougZ3M's Avatar
Originally posted by swbsam
yes the shift knob has lights and if he pulled it off that would be were his problem started.
What do you think was damaged? If it's the dimmer switch, would you know how to test it?
Old 01-24-2003, 05:19 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #8 (permalink)
Look on the inside of the shifter boot for some wires. These should be the power leads for the illuminated sahift knob. I'm betting that they ripped off and are shorting against something, cauisng the fuse to blow and killing all the dash lights. I dont think this is the dimmer switch.
Old 01-24-2003, 08:09 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #9 (permalink)
Junior Member
DougZ3M's Avatar
the thing is I don't have any fuses blown, I checked the voltage at the fuses with a multimeter
Old 01-24-2003, 07:45 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #10 (permalink)
Did you check for the wires?
Old 01-27-2003, 07:43 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #11 (permalink)
Junior Member
DougZ3M's Avatar
I checked the wires and I disconnected them at a plug, a bit down from the boot. Is there any relay associated with this? What can I test? I have rechecked all the fuses associated with the lights and they are OK.
Old 01-27-2003, 09:18 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #12 (permalink)
I think you may have fried something there. Are you saying that when you unplugged it, the dash lights still do not work? Are you sure that all the fuses are good? Im betting you've got a blown fuse somewhere.
Old 01-28-2003, 11:13 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #13 (permalink)
Junior Member
I have a 2000 M Roadster with intermittant dash lights. The problem is in the rheostat. I have removed the back panel, but can't seem to remove the plastic vent cover to access the light switch itself for cleaning. Any ideas?
Maybe your problem lies in the light switch. The connector could be jumpered to test if the switch is working.
Old 02-02-2003, 06:29 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #14 (permalink)
Junior Member
Found directions to remove Light switch at "unofficialbmw.com/ronstygar.html"
Old 02-03-2003, 10:00 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #15 (permalink)
Junior Member
DougZ3M's Avatar
M Logo Got it
guys, it was the rheostat, I had it changed and everything is perfect!
Old 06-05-2003, 06:29 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #16 (permalink)
The rheostat on the dimmer switch?
Old 06-09-2003, 02:59 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #17 (permalink)
Sorry to resurrect an ancient thread, but I have this problem and I am sure others have too since 2003. Does anyone have a better answer to this?
Problem restated: Dash illumination and lighted shift knob not are all dark, fuses intact. Problem occurred some time after I dropped the transmission to change my clutch. Thank you.
Old 03-06-2011, 09:59 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #18 (permalink)
Can the dimmer be checked with a digital multi-meter? Is this the likely culprit? Thank you.
Old 02-07-2012, 07:38 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #19 (permalink)
Copyright ©2000 - 2012, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
