Can't remove valve cover on 2007 Z4 3.0si
So, I needed to replace the valve cover on my 2007 Z4 3.0si. I am almost there but this harness/wireloom that goes across the valve cover is preventing me from removing the valve cover? Any tips or tricks to do this?
Thanks in advance. |
Administrator
Hello - take a look at the link below for the procedure. Please let us know if you have any other questions.
BMW Z4M S54 Engine Valve Cover Gasket Replacement | E46 M3 Coupe/Convertible (2001-2006), Z4M Coupe/Convertible (2006-2008) | Pelican Parts DIY Maintenance Article |
Alpinewhite did you get that off? I think you have to remove the fuel rail from the opposite side of the valve cover.
