Expansion Tank
98 base
Did a static pressure test on the cooling system today. Dropped two psi in ten minutes. No sign of a leak and fluid loss may be a few ounces. Just wondering if it should hold pressure indefinitely or if there is an acceptable loss rate. I am planning on replacing the tank. Thanks |
There is no such ting as "a acceptable loss rate" on the cooling system holding pressure. It either holds pressure, or it does not...……..
Accrochez-vous bien de vos rêves..........." |
Banned
I must agree with J F P, as in my experience, take it from me!
Sent from my VS987 using Tapatalk |
Okay!
As I said, replacement is emminent. Looks like I've connected with a couple of absolutists. Thanks guys |
