Occasional User
IMS video on PCA Jake Raby
There is a very interesting series of videos on PCA. This is the 3rd installment.
https://www.pca.org/news/2018-03-27/four-stages-ims-bearing-failure
Vince 2015 Boxster S, Black & Black 1989 Carrera Silver Coupe, Silk Grey - sold 2009 Cayman S White, Full Cocoa - sold 1972 911E Silver Coupe, Pepita & Black - sold |
Gon fix it with me hammer
so mixing oil brands is cause for shrinking the seal?
Seems a bit far fetched to me
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
No, but it can accelerate it.
Accrochez-vous bien de vos rêves..........." |
how ?
The primary cause is the grease seal is rated only for 250F degrees and with intermittent 300F. The seal is exposed to oil that exceeds these temperatures that cause it to become brittle.
Charles Navarro President, LN Engineering and Bilt Racing Service http://www.LNengineering.com Home of Nickies, IMS Retrofit, and IMS Solution |
nooo that's not what the dude said, he saidd that mixing oils has a bad influence on IMS failure progression. around 4m20, "oils mixed with other oils, somebody not sticking to the same brand"
He says that causes the seal to become brittle , and fail. So he's blaming oil changes with different brands to the stage 1 of the IMS failure mode. Which sounds like BS to me. To be honest, his entire rambling presentation sounds like a snake oil sales pitch to me. terms like "ferromagnetic fuzz that goes through the engine like liquid sand paper".. a lot of scaremongering ...
There are many contributing factors, not just one.
Sorry, but they did not say bad oil , they said switching brands is problematic.
So if by your suggestion the issue is Mobile 1, then basically all they do with the "don't switch oil brands" is make people not change from M1... Which is a good business model off course if you are in the engine rebuild business.
It'll be legen-waitforit
Sorry but Charles and Jake have forgotten more than we will ever know on the subject, I thank them for all this information.
Bob James 06 Cayman S - Money Penny 18 Macan GTS Gone: 79 911SC, 83 944, 05 Cayenne Turbo, 10 Panamera Turbo |
It's still a vague statement without anything more to support it...
And I just don't take things on face value
I did not interpret the video as suggesting that you stick with the same brand oil for the life of the engine across all oil changes. But more that a fill and top-ups should be the same brand and additives package. Don't just grab some half full oil off the shelf of indeterminate age and additives package and add it mid fill life.
While the biggest problem for the IMS seals is temperature, the newer non ZDDP oils contain some unusual compounds in their additive packages that do not play well with each other. As all oil compounders treat their formulations like they were a state secret, it is impossible to tell who is using what. In the auto repair trade press, there have been a series of articles about how mixing these newer oils can exacerbate seal hardening and oil leakage on just about any engine, even lawn mowers, so the problem is real for those of us that have to deal with leaking engines every day................
Then he really should have elaborated on that
He is a man of few words...................
I don't believe Jake has to elaborate on anything. He has given his opinion, viewers can do with it as they wish.
The video had some good points, I guess. But like lots of videos online it rambled on so much it was hard to stay with. My fault, I guess, I'm an older gearhead and I tend to be impatient with the newfangled videos.
As it turns out, my old 01 engine had a failing, but not failed IMS bearing seal. there was a lot of leaked out oil on the lower back side of the engine when I pulled it out.
Brian Lamberts Tucson AZ |
Brian, the seal in your bearing was leaking or the IMSB flange seal was leaking oil into the bellhousing area? Two very different situations.
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
I stopped worrying about this a while back. I think someone wise on the board wrote something about swapping in a 3.4 3.6 if the ims ever goes. Not that I have the money to do but I saved up my 10g to buy my car, I'll just do it again and end up with a faster car to boot. It will take a while for sure. Other Porsches have their own set of problems that cost even more to fix so not sure why the big deal about the ims. Heck I always wanted a 2011 boxster spyder. To fix the brakes on that car would cost about what my car costs. Getting back to point of post, it's an interesting video but I won't lose sleep over it. Geez, haven't thought about my IMS all summer. Thanks a lot guys. 😄
Now you guys have me worried using M1. Well not really. |
Just save up and buy a 2009 Cayman.
Will see in due time if those timing chains, spinning at twice the speed, compared to the older Porsche engines, don't introduce their own kind of problems...
They are not a serviceable item either.
