Dipstick tube won't stay put!
2001 Boxster S
The dipstick tube will not stay attached to the coolant tank housing.
The clips appear intact.
It looks like the coolant tank housing employs a knockout for the dipstick tube hole.
Is there another solution besides replacing this:
I might try taking a tiny screwdriver and prying the clips out.
Anyone else deal with this one?
Old 08-31-2018, 07:16 PM
M. Murphy's Avatar
Yes, just had to replace mine, 98 base. Had no problem with the lower connection, just a push and click. The upper was a bit more difficult because there is an o ring that must be pushed up into position. From your images it looks like the opening for the upper boss is a bit buggered and the upper clip on the guide tube appears broken. Here's how mine ended up. It took a little Super Lube to help that o ring.
Old 09-02-2018, 12:28 PM
Thanks for the reply
Old 09-02-2018, 04:08 PM
