black specks in oil filter
Opened up oil filter during oil change on boxster. can't pick up with magnet. randomly found throughout filter. Trouble coming? Any ideas or experience with same? Thanks.
Only purchased this 2002 about 2 months ago. 50K miles
Old 12-04-2018, 08:27 AM
JFP in PA's Avatar
Most likely candidate are the wear pads on the chain tensioning paddles. Common.
Accrochez-vous bien de vos rêves..........."
Old 12-04-2018, 08:38 AM
Thanks so much. So nothing I need to address right how?
Old 12-04-2018, 06:18 PM
JFP in PA's Avatar
Check your cam deviation values to see if they are in spec. If they are, you are OK for the time being.
Old 12-05-2018, 02:42 AM
Cam deviation value? Does pelican cover how to do this? Thanks
Old 12-06-2018, 12:51 PM
JFP in PA's Avatar
I have no idea what they "cover" as I pay little attention to what they say. Durametric, PST II, or PIWIS will read the cam deviations; specs are +/- 6 degrees. If you are over 6, the pads are substaintially beat and will need to be replaced.
Old 12-06-2018, 01:39 PM
the foxwell 510 or 520 will also show cam deviation.
Old 12-07-2018, 07:51 AM
I appreciate all your help. Thanks
Old 12-07-2018, 09:29 AM
