Boxster MAF installation
My 98 Boxster's old Bosch MAP has a part #996.606.123.00 stamped on it. I ordered a replacement from Pelican but I'm not 100% sure I ordered the correct part and before I open it up and install it, can you tell me if I ordered the correct part#. The new MAP I received is made by TPI and has the following stamped on it: TPI MAF1127 A171200020 and on the back side of BOTH the old part and the new part there's another stamped code: >PBT-GF 30<
Did I order the correct part?? Thanks |
Administrator
Hello and welcome to the forum Rob - according to our site wizard and car configuration, the part should work. You can always give us a call at 888-280-7799 and one of our Porsche part specialists will be able to confirm for you. Hope this helps you out.
Bosch 0.280.217.007
Sometimes sold as B3130-70627 is the part Porsche put their 123 part number to. Boxed it and added cost. Lots of info here. |
