HID headlights conversion
... have a 2007 Boxter S ... recently converted my halogen headlights to HID ( Morimoto Elite kit- H7A, 6500k, 50W) ... main beam only .. look great, w/one small complaint ... notice a 'light' shadow in each beam center ... I'm guessing it's a result of the bulb base to top ignition wire running outside the bulb 'shadowing' the beams ... the bulb can only be inserted (keyed) with the wire facing upward, the upper side of bulb ... there was no option to select bulb with wire facing downward, below bulb ... any thoughts? comments? suggestions? Tx
Old 10-24-2018, 04:11 PM
... is this post in the right Forum?? ... not a single reply after 122 views!?
Old 11-07-2018, 01:33 PM
Administrator
Dmitry at Pelican Parts's Avatar
I suggest posting this in our 986 forum, it is dedicated to just the Boxster/Cayman.
Porsche Boxster and Cayman Discussion Forum, DIY Technical Advice, Parts and Cars for Sale - Welcome to the 986 Forum!
Old 11-07-2018, 02:11 PM
JFP in PA's Avatar
Caused by the lens being designed for halogen bulbs, not HID which use a different projector assembly. The factory bulb is also a 35W, so be ready for some lens discoloring from the excess heat of the 50W bulb.....
Accrochez-vous bien de vos rves..........."
Old 11-07-2018, 03:23 PM
2007 Boxter S HID Conversion
... tx for the response ... manufacturer (Mirimoto) states igniter wire external to bulb '.. probable cause of shadow..' ... when I purchased kit, there was no choice selecting wire location above or below install ... altho I agree with your comment rel to higher heat level (obviously) generated if bulb is 50W vs 35W, manufacturer says no problem?? also, they've obviously had consumer 'shadowing complaints', as they now offer both top vs bottom ignition wire configurations!! guess I lose!!
Old 11-15-2018, 11:32 AM
Science is NOT optional
rbogh901's Avatar
Do we need a different log in for this forum? Is it a Pelican forum?
PCA member since 1993
Old 11-11-2019, 06:43 PM
