rufrob's Avatar
Stiff Shifter
I have done some searches and nothing seems to match my issue, or the threads simply stop without a satisfactory conclusion.
A friend bought a Boxster at auction which would not go into Park. I checked the cable, links and switch, all are fine. I removed the oil pan to find the link inside has separated from the slide rod. I loosened the valve body enough to reattached the slide rod and re-torqued the valve body. Refilled the transmission with new filter. When cold it selects gears and drives fine. But as it warms up, the selector gets stiffer until it pops out again and I cant select park. Which means as the transmission warms up something is binding the slide rod inside the transmissions.
Does anyone have any insight as to what I should do next?
Rob
Never give up
Old 02-10-2019, 03:55 PM
Rob
Weird one. I got nothing.
Old 02-10-2019, 05:07 PM
rufrob's Avatar
More digging points to a blocked oil cooler. There was a pool of atf after the car cools. Does anyone know the symptoms of a bad transmission oil cooler?
Never give up
Old 02-17-2019, 01:28 AM
rufrob's Avatar
I changed the oil cooler but the transmission still gets really hot. Hotter than the engine. And there is some oil in the coolant.
Any ideas?
Never give up
Old 04-30-2019, 05:40 AM
JFP in PA's Avatar
Any ideas?
Yup: Now you know why it was at the auction.....
Accrochez-vous bien de vos rves..........."
Old 04-30-2019, 08:07 AM
