-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   3.2 Tip into a 3.2 6spd? (http://forums.pelicanparts.com/boxster-cayman-forum/1036041-3-2-tip-into-3-2-6spd.html)
Brian Minson 07-30-2019 03:42 PM
I found a used 3.2 Tip motor and wasn't sure if there was anything different about the Tip motor versus a 6 speed?
Brian
2001 Boxster S 6spd
https://youtu.be/G5pt_hXDNEk
Brian in Tucson 08-11-2019 09:49 AM
Differences in the wiring harness, an extra computer module in the trunk, a small difference in the vacuum system, and more tubes and hoses for the cooling system. The alternator may be different, too. The alternator for the 6 speed may have a ratcheting drive pully.
Switch all the stuff from your 6 speed motor to the tip motor. It will all line up and the engine will work fine. I did the opposite on my 01. Really was the least of my problems switching engines.
