97' boxster roof mechanism up-grade
Hi everyone,my first post here; i am replacing the early type convertable top roof and mechanism to the later type roof and mechanism, on a '97 boxster. Replacement parts from '03 boxster.This changes the plastic rear screen to a glass one.The gearboxes,mounting studs, (and motor,if necessary) are easy to change, but, i am unsure what electricial modifications need to be made to the early type circuit, ie.module, windscreen- top microswitchs, 'b' pillar microswitch, and the microswitch on the top of the drive motor. The later type set-up gives a lot less trouble. I'm sure someone must have done this. Any advice will be greatly appreciated. TG
Old 08-05-2019, 08:15 AM
Administrator
Dmitry at Pelican Parts's Avatar
Hello and welcome to the forum! Take a look at the 2 links below to some tech articles that we have in regards to the convertible top. Please let us know if you have any other questions.
https://www.pelicanparts.com/techarticles/Boxster_Tech/70-BODY-Convertible_Glass_Window/70-BODY-Convertible_Glass_Window.htm
https://www.pelicanparts.com/techarticles/Boxster_Tech/71-BODY-Convertible_Top_Repair/71-BODY-Convertible_Top_Repair.htm
Old 08-05-2019, 04:13 PM
You may find Maurice's write up helpful...
https://sites.google.com/site/mikefocke2/installinga%2703-%2704glasstopandframeona%2797
Old 08-07-2019, 11:57 AM
