P1125, p1123, p0455
Hello to all,
This is my first post. Have a 1999 Boxster.
Currently getting codes P1125, P1123. My Autophix OBD2 scanner is telling me the P1125 is o2 sensing i.e. oxygen sensing adaptation area1 cyl 4-6 lean threshold.
P1123 is the same info for cyl 1-3.
A month ago I had a P1119 and the Porsche Mechanic I use replaced an oxygen sensor.
Any thoughts as to what I should look at?
Thanks,
Carl
Old 11-25-2019, 10:55 AM
JFP in PA's Avatar
You are leaking air into the intake system somewhere.....
Accrochez-vous bien de vos rêves..........."
Old 11-25-2019, 11:16 AM
Im not very familiar with the Boxster engine. Anything specific I can check?
FYI this car has only 36831 Miles. Got it when it had 12400 mi.
Old 11-25-2019, 11:47 AM
JFP in PA's Avatar
Start with the obvious: Vacuum lines, intake connections, etc.
Old 11-25-2019, 02:27 PM
