Trans fluid change
Hi all,
I could use a little help with changing the tiptronic fluid in my 2007 Cayman base.
Does the drain plug get a crush washer?
Is sealant used on the fluid pan?
Thanks for the help.
Gary
Old 01-28-2020, 03:55 PM
Brian Minson's Avatar
If I remember right, I think the drain plug has a rubber o-ring, and there is a special gasket for the plan. Do a search here on PelicanParts for what you will need.
Brian
My Porsche YouTube Channel
Old 01-29-2020, 07:13 AM
Brian,
Thanks for the reply.
I contacted the Porsche person at Pelican and he agreed with you. An o ring is needed on the filler plug but he was not completely sure about the drain plug. He felt it may be a tapered thread and would not need a crush washer. I am going with his best opinion and just screwing it in. As for the gasket I am not going to use a sealant and see what happens.
Thanks again.
Gary
Old 01-29-2020, 08:38 AM
