-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Tip Shifter NOT locking (http://forums.pelicanparts.com/boxster-cayman-forum/1051022-tip-shifter-not-locking.html)
RickKlem 01-27-2020 10:27 AM
Will not start, immobilizer may be bad?
I have a 2000 Boxster non S and it had a busted front windshield so I DROVE it up on a trailer and took it to have it replaced. When I arrived at the shop I drove it off the trailer and then drove it back on when they were done.
When I tried to start it the next morning to unload it from the trailer it would not crank or turn over. I checked under the seat and water had got down to the immobilizer. I am trying to clean it up and dry it and I will test it to see if it is toasted. If it is I will contact Steve to see if he can repair it.
Question 1 : While working on the issue I noticed that the Tiptronic shifter can be taken out of Park and ran through RND without a key in the ignition or without a foot on the brake. I don't recall if I could do that before the starting issue. Is this normal and what is allowing it ? Could this be a sign as to why it is not turning over or attempting to crank? Could it be that something happened during the tow?
Question 2: Once I reinstall the immobilizer and plug it in can I attempt to start it as a test WITHOUT reinstalling the seat and plugging it in . I have heard that if I turn the key on while the seat is unplugged the airbag CEL will trigger and i will need to have it reset at the dealer.
Thanks for any help
Rick
Brian Minson 01-29-2020 07:16 AM
Rick, I can tell you that you can leave the seat out of the Boxster and still start the car. I just had to go thru this issue with my immobilizer... what a pain in the @$$ and MONEY... But my car runs now! Here is a little video on what I did to my Boxster, https://youtu.be/BOB2cL2J6XU
Brian
RickKlem 01-29-2020 07:52 AM
Brian,
So it didn't throw any airbag errors when you cranked it with the seat out, that is good news. Great video, I guess it was ECU Dr that you sent it to. I will contact them to see how much $$$.
Thanks for your input
Rick
