-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Window will not drop on door open (http://forums.pelicanparts.com/boxster-cayman-forum/1059437-window-will-not-drop-door-open.html)
bobmackool@gmai 04-28-2020 05:30 AM
I have replaced the regulator and the micro switch, but my 1998 Boxster passenger window will not drop the few mm to open/close door. It does come down automatically with conv. top switch, it works from window switch. looking for what i should dig into next?
Blue99 04-28-2020 10:08 AM
Hi when you say replaced the micro switch do you mean the one in the lock mechanism as that is where the switch is to drop the window.
I messed around with my lock mechanism for ages cos the window stopped dropping. In the end I bought 2 lock mechanisms ( both doors ) and everything worked properly again
gkeller 04-29-2020 12:29 PM
had same on 02 boxster s , didn't want to pull regulator cause it looked complicated and the window did go up and down and was tight in full up or down, inbetween i could pull window up or down a half inch, dove into it and not that bad a deal, replaced and works great,only thing is when you reconnect the air bag it triggers a light on dash, porsche wanted two hundred to reset, found a local for fify, ifn I had to do again might try to cut the insulator around bag and leave it plugged in
