-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Ignition switch Failed (http://forums.pelicanparts.com/boxster-cayman-forum/1064728-ignition-switch-failed.html)
BYprodriver 06-19-2020 08:53 AM
2000 Boxster S made January 2000. Ignition switch locked up, I can't insert key or remove key tumblers following Wayne's instructions from his book. I have removed the Ignition switch from under the dash.
BYprodriver 06-20-2020 09:22 AM
Hello , Hello.
tcora 06-21-2020 04:40 AM
Is there a question in there somewhere?
BYprodriver 06-22-2020 04:13 PM
How can I remove the ignition switch where the key inserts?
tcora 06-22-2020 04:54 PM
Hmmm. You don't have a lot to lose at this point, but you don't want to trash things, clearly. I'd try loading the key slot up with WD40 and then gently trying to work the key in. Let it sit for a bit and try again. Patience and lubrication are going to be your friends...
BYprodriver 06-23-2020 09:42 AM
Did that a couple months ago
tcora 06-26-2020 04:42 AM
Find a good locksmith, or replace the entire assembly, then.
