Running down a ...P1319 (dream)
My Ď97 Boxster base stalled at work , not that uncommon , but itís not usually acccompnied with a flashing CEL.
The durametric gave me a code for the CMP
P0342. So I replaced both. Now I have bank one codes p0300 P1319 , p0301-0303 , and p1313 -p1315.
1 time it threw 1313 so I checked the coil and it broke while getting the sleeve off. So I replaced the plug also.
Remapped . Same codes after clearing and mapping.
I know what they mean, but I canít figure out where the air is coming from.
It wasnít long ago that a code for a incorrect purge overflow come up. So I did the easiest thing , which was buy an original Porsche gas cap and installed it. The code went away and hasnít returned.
During startup the sai comes on and idles at 800 rpm then shuts off and drops to 600 and a rough idle for about a minute before the flashing light comes back.
Iíve done a lot of projects on this car.
Clutch-IMS, replaced an injector, fuel pump, O2 sensors, CPS, chain tensioners, plugs coils and wells. Starter , exhaust, coolant overflow tank, horns , heater box flaps, intake manifold , AOS and all of SAI system components , and suspension components . Other stuff as well.
I enjoy fixing it and doing the work with my own hands.
But this time...idk
Might be time to take it to dealer and have it tested.
Any thoughts , enthusiasts?
Old 09-23-2020, 08:28 AM
