-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Problem (http://forums.pelicanparts.com/boxster-cayman-forum/1076036-problem.html)
hot wheels 10-18-2020 04:22 PM
Problem
I have a question on my 2007 Porsche cayman base I'm in the process of replacing the clutch in this vehicle. After removing the transmission, I noticed that the rubber elbow from the air cleaner to the intake pipe was all caved in and distorted. I removed it thinking it was installed incorrectly I noticed how offset the two pipes were. I worked on it for more than a hour trying to get it back together I tried to get the kinks out with no avail. It looks the same as when I removed it.Its so kinked I'm afraid its restricting the intake air flow. Anybody haven ideas? I tried lining the seam but made no difference
tcora 10-19-2020 04:10 AM
How are you supporting the back of the engine? It sounds very much like it’s dropped down (as you’ve removed the transmission) and that is what’s causing the issue you describe.
hot wheels 10-19-2020 08:23 AM
Never thought of that, I will see if this the problem, Thinking about it you have to be right. Thank you so much. I'm learning!!
hot wheels 10-19-2020 10:10 AM
problem solved
Thank you again for the solution, I felt like an idiot when i jacked up the engine and pop, it was all straight. sometimes the simple solutions are totally overlooked. I looked into the mirror and slapped myself and said get with it man. Thanks
tcora 10-20-2020 04:16 AM
Doncha hate when that happens?
I’m pretty sure that nearly every person who has looked at this thread has had a similar experience. I certainly have (more than once)!
hot wheels 10-20-2020 05:28 PM
fly wheel torque
On my 2007 cayman I put a new flywheel on, torqued the bolts to 19.00 ft pounds marked 120 degree marks on each bolt and began the final tightening. I'm using a 2ft breaker bar to get to the mark. I'm up to about 90 degrees on each bolt. I'm pulling so hard on the breaker bar I'm afraid I'm going to snap the bolt before I get to the mark
My question is, Is this normal?? should I keep going?
JFP in PA 10-20-2020 06:19 PM
Yup.
