987 Boxster coolant system problems...help!
Replaced the water pump, after a failure, and the thermostat. Refilled using a Venturi/vacuum fill tool. Instrument cluster temperature gauge never moves off of 100° and low level light flashes at one/sec. Live data using a scanner shows engine temp rising appropriately as I let it run until it achieved 155°. Light still flashing and gauge shows 100°, the lowest it goes. Sooooo?
Old 12-14-2020, 03:12 PM
Tags
low coolant level , temperature gauge
