-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   2.7 to 3.2 Engine swap question 2003 986 (http://forums.pelicanparts.com/boxster-cayman-forum/1084071-2-7-3-2-engine-swap-question-2003-986-a.html)
Steve_1302 01-22-2021 02:35 PM
I have a running 3.2 from a 2004 model Boxster S lying around so I figured it is time to do something with it. I found a 2003 Boxster that has a bad engine, but it is a 2.7. Can I use the wiring harness from the 2.7 on the 3.2? The 2.7 DME should get it running, but probably needs to be flashed to 3.2 eventually, right?
BYprodriver 01-23-2021 09:45 AM
I am pretty sure you will not have to change any thing, the DME supplys fuel to match what the MAF sensor air flow detects. I rebuilt my 2000 Box "S" 3.2 to 3.6 liters in 2009 & have never touched the DME
Steve_1302 01-24-2021 05:10 AM
Thanks for the info on the DME. Do you happen to know if a 2.7 wiring harness will work on a 3.2 of the same year?
BYprodriver 01-25-2021 11:17 AM
Yes it will.
racer 01-26-2021 05:00 AM
I believe the only issues with swaps was if you had an E-Gas engine going in an early car (but there are ways around that).. you should be fine to put an 04S engine in an 03 base. Depending on use, you may want/need the larger brakes, additional radiator and 6spd from the S too...
