2.7 to 3.2 Engine swap question 2003 986
I have a running 3.2 from a 2004 model Boxster S lying around so I figured it is time to do something with it. I found a 2003 Boxster that has a bad engine, but it is a 2.7. Can I use the wiring harness from the 2.7 on the 3.2? The 2.7 DME should get it running, but probably needs to be flashed to 3.2 eventually, right?
Old 01-22-2021, 03:35 PM
I am pretty sure you will not have to change any thing, the DME supplys fuel to match what the MAF sensor air flow detects. I rebuilt my 2000 Box "S" 3.2 to 3.6 liters in 2009 & have never touched the DME
Old 01-23-2021, 10:45 AM
Thanks for the info on the DME. Do you happen to know if a 2.7 wiring harness will work on a 3.2 of the same year?
Old 01-24-2021, 06:10 AM
Yes it will.
Old 01-25-2021, 12:17 PM
racer's Avatar
I believe the only issues with swaps was if you had an E-Gas engine going in an early car (but there are ways around that).. you should be fine to put an 04S engine in an 03 base. Depending on use, you may want/need the larger brakes, additional radiator and 6spd from the S too...
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 01-26-2021, 06:00 AM
