Quick wheel and tire question
Anyone know if I can run a +1 setup on the stock wheels? Specifically, can I mount the following:
245/40-18 tires on 8J x 18 wheels (Front) 275/40-18 tires on 9J x 18 wheels (Back) I know that it really depends on the tire selection, which would be the Yoko Advan A052's. Looking to get a third set of wheels for the car to be used as my "backup" set for the track. (Current track wheels that I have are wider at 8.5J x18 front, 10J x 18 year). Thanks!
2010 Cayman S - 12-2020 - 2014 MINI Cooper S Coupe - 05-17 - 05-21 1989 944S2 - 06-01 - 01-14 Carpe Viam. <>< |
You might want to check with Tire Rack on a question like that.
Tony G 2000 Boxster S |
I checked with my tire guy, and those tire sizes will fit stock wheels.
I know a lot of folks upgrade to 19's and such, but I can't see how there would be huge gains by doing so, especially for HPDE track days, and autocross. A set of tires for 18's are cheaper than 19's, which allows me to spend money elsewhere on my car...
2010 Cayman S - 12-2020 - 2014 MINI Cooper S Coupe - 05-17 - 05-21 1989 944S2 - 06-01 - 01-14 Carpe Viam. <>< Last edited by Z-man; 05-17-2021 at 01:17 PM.. |
Autocross guys will tell you that smaller diameter wheels are better for quick exits than larger diameter wheels. You might look at 17's for AX
You will be fine with those tires on your stock wheels. 10mm wider front and rear. If you want to stick with the 18's, consider wider wheels for your Cayman S. We generally spec a 9.0 F and 10.0 or 10.5 rear. Stock size tires or the slightly larger ones you want will work great.
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
