Help! where is the Theft Control Module?
Help!!
Where is the Theft Control Module located? I am replacing the ECU, Ignition barrel, door lock, steering lock and "Theft module control unit (Key ECU)" labeled as M 5X5 on the box but am unsure where it is located in the car. It's not the one under the drivers seat. Thanks, Julianhttp://forums.pelicanparts.com/uploa...1618847718.jpg |
Found! under the dash on the right of the steering column, placed vertically and above the AC duct.
| All times are GMT -8. The time now is 02:00 AM. |
