-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Replace mass air sensor (http://forums.pelicanparts.com/boxster-cayman-forum/1093262-replace-mass-air-sensor.html)
ASD 05-12-2021 02:45 PM
I've done the on several vehicles, cleaned a few,replaced a few.I'm about to do this on my 986 anything special to consider?
mikefocke 05-12-2021 05:08 PM
A special tool of the correct size...T20 security torx. The “Tamper-Proof Torx” looks like a screwdriver bit with 6-point bits (star shape). The tamper-proof aspect is that in the middle of the 6-point bit, there is a little hole in the bit so you need the special bit, not just the more common Torx. Make sure you get these, not the regular Torx bits that do not have the hole.
Lots of details and the cheap part numbers https://sites.google.com/site/mikefocke2/checkenginelightcausedbymassairflowsensor
Why are you throwing parts at it? Especially expensive ones. Diagnosis first.
I'd be cleaning the throttle body and intake and checking the AOS first.
ASD 05-13-2021 04:37 AM
diagnostic said it spikes and then reaches low limit before spiking again.The part is not too expensive its the labor they quoted that is tough to swallow, Especially for a guy that used to do all his maintenance.On my 911 it only was in a shop once.
Luckily i have two sons who are quite handy with it.One owns a boxster, the other is a factory tech for yamaha motorsports.So we should be good.I will direct.
mikefocke 05-13-2021 05:36 PM
It is simple, and obvious with the right tool. I cleaned my MAF once and it was original at 70k or so miles.
ASD 05-13-2021 06:24 PM
I have used mas cleaner spray on other cars.
So i need to buy the torx type tool.i can do that.
I will save 500.doing it myself
ASD 05-13-2021 06:28 PM
Also the diagnostic said fuel cap..I ordered one.mine has cracks in gasket
