Hello,
I recently had my clutch pedal go thump when I shifted from 1st to 2nd. The problem turns out to be a small hole in the clutch line just above the point where it comes out through the bottom behind the front wheel. It had been rubbing itself slowly along a rough edge on the inside of the car body. I'll have to replace the whole line. Does anybody know the best method for removal/replacement?
R
Hello,
Replacing the clutch line that leads from the master cylinder line to the clutch line connection point under the car. Can't figure out how to disconnect these two points.
Any suggestions?
Old 06-20-2021, 05:35 PM
