987.1 3.4L Vacuum Line Diagram
I have a 2006 Cayman S that I am replacing the AOS and lines. I removed the intake runners to install the lines and to track down an oil leak. However, after removing the runners I discovered that only two of the vacuum lines were connected to anything. I have looked online for a detailed diagram of how the vacuum lines should run and the diagram on the engine cover is vague.
Does anyone have a detailed vacuum line diagram from a service manual?
Thank you in advance.
Old 09-18-2021, 02:24 PM
What's that part number on the right hand side beginning with "987 xxxx" please? I can't quite read it. I'd like to order one of these to stick on my engine access panel.
I have already printed one of these and stuck it to the aluminium panel behind the seats under the carpet to make my life easier
Old 09-28-2021, 06:32 PM
Sorry, I pulled the picture offline. There was not one on my car to get the part number off of it.
I did find a photo and was able to route the vacuum lines properly.
Old 10-06-2021, 03:54 PM
