986 oil
What Mobil one oil for a 986?
0W40 5W30 0W30 Other? |
Time to put the popcorn on................
Accrochez-vous bien de vos rêves..........." |
5W50 or 0W40
![]() Sent from my ONEPLUS A5000 using Tapatalk |
Rtfm
Tom Coradeschi 03 Boxster |
Is there any preferred brand of oil to use? Total? Motul? Liqui Moly? Mobil 1? Not to start an oil information war but just practical reasonings I can look at for my own information. Thanks.
why not use Rotella?
1999 Carrera2 tip arena red 2000 Boxster S tip...arena red ....black 1981 911sc targa...grey mkt.import...Rosewood 1978 911SC, guards red sunroof delete .much missed 73 914 2.0 found in a bunch of cardboard boxes, and brought back from the dead. |
i dont get it?Eyebrows up?
I used Rotella for years in my 911sc, never had a problem.But Tractor Supply sells Mobil 1 for decent prices.
The Shell Rotella Gas Truck product is recommended for use in gasoline pickup trucks and SUVs that face even the most extreme conditions including heavy hauling, towing, extreme temperatures and off-road because of its unsurpassed protection. We know that gas truck owners want a motor oil that delivers on key benefits including protection for extremes their engines face. Shell Rotella Gas Truck is all about hard work, and we know that many gasoline-powered pickup and SUV drivers, particularly those with 4×4 vehicles, use their trucks for hard-working purposes. The product is also suitable for gasoline pickup trucks or SUVs that do not face these types of conditions as well. The SAE 5W-20 and SAE 5W-30 viscosity grades are recommended for use in all vehicles under all driving conditions. And the SAE 0W-20 is recommended for all vehicles that allow the use of an SAE 0W-20.
i will likely buy Valvoline or similar 5w40
ok gotcha.At a decent price ill use the "quality oil"If not the length between changes would be shorter.
What you should be looking at is shear strength, and the level of ZDDP in the oil; most of the product's mention have little to no ZDDP in them, or are not known for their shear strength.
This is an old BIG topic and popcorn helps! Here are my 2 cents ...After 1994 the industry had made changes to operate without the higher ZDDP content. Opel was one of the manufacturers that stretched it out to 1996. The Porsche factory/engineers recommend Mobil 1 as do most of the European manufacturers. So, going with Mobil 1 or anything that specs out to be equal or better is a good way to go! I as well as many of my serious car guy friends use Mobil 1 in some of our cars and also use Liqui Moly oil and their oil additives and believe it is better than Mobil 1. Porsches are worth using quality oils
1981 Porsche 911SC, 2001 Porsche Boxster, 1963 Jaguar MK2, 2001 Jaguar XJR, 1991 Mercedes 500SL, 1973 Opel GT, 1981 Mercedes 380SLC, 1994 BMW 325ic, 1980 BMW 320is, 1983 BMW 320i, 1974 MGB, 1999 Audi A6, 1995 BMW 740iL, 1995 BMW 325iC |
i believe in liqui moly..bought their additives.
Their oils are awesome. Their additives are amazing! They actually work
i used to own an 81 rosewood targa
You need to do your research, find oils that have high ZDDP levels, which contrary to published BS, do not harm catalytic converters on properly maintained engines.
My research was done decades ago and I'm still on top of that subject. How about you???
1981 Porsche 911SC, 2001 Porsche Boxster, 1963 Jaguar MK2, 2001 Jaguar XJR, 1991 Mercedes 500SL, 1973 Opel GT, 1981 Mercedes 380SLC, 1994 BMW 325ic, 1980 BMW 320is, 1983 BMW 320i, 1974 MGB, 1999 Audi A6, 1995 BMW 740iL, 1995 BMW 325iC Last edited by 81SCRosewood; 10-27-2021 at 03:28 PM.. |
