2001 Boxster S won't start
2001 Boxster S won't start. HELP IF YOU CAN!!! Charging battery, lights are strong horn works. Sounds like an auxiliary fan has been running. Can hear it and feel the vibration passenger side fender near windscreen. Could be heater/defroster related, seems to be near cabin air filter.Any fuses to disconnect?? Any ideas Thanks, b rock
No tach movement would suggest faulty crank position sensor. Report back... |
Does it crank?
We had one that would crank, but not start. Unplugged the faulty MAF and it fired up and drove home.
SWB 912 - G50 Carrera - 986 Boxster - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo Workshop Coordinator at Ehrlich Motorwerks instagram.com/patrickossenkop ehrlichmotorwerks.com |
Thank you for your helpful suggestions. Have it at the shop. Looking to see if the fan sound might be the motor that locks tne fuel door. Will check crank position and report back. b rock
looks like drain holes were clogged. Lots of water under carpets. Alot of actuators were sitting in water. Checking to see which ones were damaged.
It might be salvageable and repairable if you send it to ECU Doctors.
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo 2001 996 GT2 1999 Spec Boxster, 1996 993 Cabriolet 1992 964 Cabirolet, 1975 911 RSR Replica Race Car |
Many independent shops can program a replacement immobilizer, we do a few each year for the same reason, water damage.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
So -- what happened?
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
