Torx Size for Clutch Bracket?
Does anyone happen to know what size Torx head the bolt is that holds the bracket for the clutch cables is?
I need to buy one, and wondering if I can avoid buying a whole set. |
Ah, good point. It's a 2000 S. The Torx size is very big. So it would not be in a standard set.
http://forums.pelicanparts.com/uploa...1649080047.jpg |
Ah, solved. I see there is a chart for it. I just need to get under and measure. If anyone happens to know, it will save one up and down of the car.
https://www.wihatools.com/torx-sizes |
