1998 Boxster key won't turn. Car won't start
Hello. I have a 1998 Boxster and when I put the key in the ignition, it will not turn. I even ordered a new key by my VIN and still nothing. I went under the dash and removed the ignition switch and tried to turn it with a flathead screwdriver and all the light come on but is the car supposed to start considering the steering wheel is still locked because I couldn't use the key??? Any help would be greatly appreciated. I'm a former owner of a 1977 928, 1977 924, 1984 944, & a 1985 924s but I always wanted a Boxster and ran across this car very cheap and it came with a hardtop attached but I can not get it to start.
Old 05-06-2022, 06:32 PM
The key receptacle has a sensor in it which interrogates the RFID pill in the key. With the ignition switch turned On the key still has to be in the receptacle for the immobilizer to recognize it.
Old 05-07-2022, 07:01 AM
It sounds like the steering lock assembly may be faulty. You could try and get access to the piece and try and free it up but it will be the same amount of work as simply replacing the entire assembly. People say this is a huge project but I did it and while you have to remove the instrument cluster, etc., it is pretty straightforward. BTW, doing this will also address any electrical gremlins an old ignition switch can cause - https://www.pelicanparts.com/More_Info/99634701707.htm?pn=996-347-017-07-M100&bt=Y&fs=0&SVSVSI=1042
'87 Carrera Cabriolet
Old 05-08-2022, 08:55 AM
jluetjen's Avatar
Are you sure that the steering column isn't slightly loaded (which can make the lock stick in the column)? I noticed in the picture that the steering wheel is turned a little bit to the right. If you move the steering wheel a little right or left when trying to turn the key, does that help?
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 05-10-2022, 06:03 PM
I winded up purchasing an entire lock cylinder with a key. I installed it but the car will not turn over. Shouldn't the starter atleast click?
Old 05-18-2022, 10:36 AM
So now the steering wheel is unlocked but the car will not start
Did you switch the pill inside the key from the old key to the new key?
Sent from my SM-S908U using Tapatalk
Old 05-18-2022, 10:50 AM
I didnt switch that. Didnt know I had to
Old 05-18-2022, 01:10 PM
That pill talks to the Immobilizer.
Old 05-18-2022, 03:11 PM
That worked!! I switched the little pill looking thing and the car started. Thank you so much. You all were a major help. Now I'm able to start restoring my Boxster. Again, I really appreciate all the help.
Old 05-21-2022, 11:11 AM
Awesome. I'm happy that I could help.
Old 05-21-2022, 11:39 AM
Tags
986 key ignition stuck
