-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Replaced the timing chain guide rails with the ENGINE IN! (http://forums.pelicanparts.com/boxster-cayman-forum/1119559-replaced-timing-chain-guide-rails-engine.html)
TTGator 05-25-2022 11:35 AM
Part 1 of 2 is out! Changing the cam timing chain guides/rails with the engine IN THE CAR! I'm making 2 versions. This is the "condensed" version and it's still an hour long (and only half the job). Hits all the high points of the job for those of you who are curious. The "detailed" version is over 3 HOURS of, well, the FULL detail of the job with additional tips and tricks. If you are actually going to DO this job, I HIGHLY recommend the longer version. Enjoy!
https://youtu.be/O037gHuapCI
TTGator 05-27-2022 11:20 AM
Part 2:
https://youtu.be/UBn9ilAwF78
mistertate 05-30-2022 09:41 AM
That’s really cool that you figured that out
