987.1 Convertible wont open
Hi guys,
got an issue with the convertible top that wont open at all. Have checked Fuses for top are ok Relays are checked swithced close relaywith open relay and close signal seems to work. Checked micro switches with OBD tool they actuate as they should and handbrake light is also checked. Windows wont drop down and nothignseems to happen when i release the latch. When I pull the close button I get a message in the instrument panel that the top is closing. But when I press for opening nothing happens. Windows does not drop and clamshell does not respond. I also tried to open the top with my OBD tool but nothing happens. Rear spoiler works. Everything else is working fine. Anybody got any ideas? Best regards Jonas |
Is the open side of the button defective? I read your post twice and didn't see that you ran any tests on it.
I'm not an electricial, I didn't play one on TV, and I didn't stay at a Holiday Inn. |
Actually I had no way of testing the button so I replaced it. Brand new button but same issue.
