Window does not drop when I open the passenger door
Hi all hope you can help I have a 2000 2.7 tip S auto RHD
The passenger window does not drop when I open the door Have changed the microswitch on door handle which has worked for the past year or so But has started with the same problem, I have tried another new microswitch which has not cured the problem. Could this be the door lock ? Or something else. Hope you can help. |
| All times are GMT -8. The time now is 05:17 AM. |
