-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Non-Functioning Key Fob (http://forums.pelicanparts.com/boxster-cayman-forum/1136637-non-functioning-key-fob.html)
fisher22 05-13-2023 08:30 AM
$70 shipping is robbery. They need to be called out on that!
ASD 05-24-2023 06:33 AM
the whole thing is a major rip off.Porsche needs to be a bit more customer friendly,i know they could give a crap...but....
seeyoulater 11-06-2023 08:25 AM
Summation...
Purchased my vehicle in May '22 and the fob became glitchy, requiring multiple presses to open the door.
Changed batteries and it to no longer opened the door, regardless of how many presses.
The door latch had no resistance, which required me to carefully gain access.
Purchased a used door lock actuator for $38 but it was not needed.
Replaced the lock cylinder (Dealer $560!). I thought that I may break the new white plastic cylinder as the fit is very tight. Good thing it is flexible.
I can now open the door with the new lock key but must insert ignition key quickly in order to avoid setting off alarm. The original key will start the car.
http://28090
http://28091
fisher22 11-06-2023 10:16 AM
Sounds like you have a good workaround, if you’re ok with just using the manual key.
