Overheating issues
I am having over heating problems with my 2005 Boxster. Base model. Tank isn't leaking. Do thermostats fail in Boxsters often? Any help would be appreciated. Also I live in Florida so its always hot.
Overheating is a big problem. This can crack the head. I’d start by removing the front bumper cover and cleaning between the A/C condenser and the radiator. You can’t see between without taking it apart. It will have a ton of crap in there.
Also check the fan is working correctly. Start the car, turn on the A/C and both fans should be running. These fans can fail and may need replacing. Start there. Step 2 is cleaning between the rad and condenser. Don’t wait. |
fyi- mine had a hairline crack on the tank bottom.It didn't leak until the car was well warmed up, and the leakage was small but steady then.
Thank you for the information. Much appreciated..
Are the fans comming on? Start there.....
cleanin out the area in fron of the radiators is mandatory, i put screening over theg rills in to prevent the build up of leaves and crap
| All times are GMT -8. The time now is 02:10 AM. |
