Boxster no electrical power at all
Hi to all. New member here. 2002 Boxster S race car lost all power. Checked following:
Battery checked, good 12.9 v, power goes to alternator , I changed voltage regulator anyway, checked all fuses including 80amp fuse, replaced ignition switch with URU from amazon, after multiple on off attempts I had lights on the dash but all dead after few seconds. The immobilizer is on the side and not getting wet, opened and checked, looked fine. also checked immobilizer fuse-ok. Well, don't really know where to look now. Has anyone here had similar issue?
Old 06-11-2023, 05:26 PM
You might look at the long ground wire from the battery. Clean and reattach both ends.
Tony G
2000 Boxster S
Old 06-12-2023, 03:36 AM
Thanks for the reply. Will try.
Old 06-19-2023, 10:31 AM
Does the ground cable starts from the battery area and ends at the engine firewall? Trying to locate?
Old 06-19-2023, 11:19 AM
I’m not sure of the route. I know a few guys in our PCA Region that had them replaced at a local shop. It is a PiTA procedure but it should trace back to a body part for grounding. Engine and trans also has a ground to the body. Maybe check that one first and then use a makeshift ground from the battery to a clean bolt or other steel ground.
Tony G
2000 Boxster S
Old 06-19-2023, 03:47 PM
To firewall, yes. I had to replace with a longer cable on a '01S when I changed to a smaller battery. Common autoshop cable, nothing special. Trivial if I can do it.
Old 06-19-2023, 05:12 PM
OK. Thanks
Old 06-20-2023, 09:07 AM
Smile Solved
OK, everyone, I found the problem. The issue was the defective kill switch, when checked power to the main fuses it was zero amp. Strange, because I thought that was first thing I checked but I guess not.
Connected positive with the main fuse wire and car started like a champ. Thank you all for the help.
Old 07-12-2023, 07:19 PM
Going faster all the time
Litesonic's Avatar
thanks for telling us the resolution... not everyone "gives back" so to speak.
Now: 1997 German-built Boxster - Black
Then: (2) 1973 914 2.0 Marathon Blue | 1986 944T Alpine White | 2004 40th AE 911(996) #898 | 1987 944 Guards Red | 1976 914 2.0 Summer Yellow | 1974 914 2.0 Light Ivory | 1986 944T Black | 2006 Cayenne Turbo S - Titanium Gray
Old 07-22-2023, 03:12 PM
