Engine inspection
2014 Cayman, 25,000 miles.
I'm accessing the covers on the engine compartment to inspection the engine, looking for anything out of place like wet leaks.
I have the front cover off behind the seats the belt looks good there is a number on it, 060w-14, is this the date code 2014?
The top cover is ready to be removed next.
What should I be looking at to inspect for wear?
I replaced the air filters, they were quite dirty.
Did oil change, the over fill light on dash was coming on I measured about 9 1/2 quarts that came out, refilled with 8 quarts and level is now in range.
Old 04-03-2025, 12:31 PM
This thread needs pitchers
Wiped the top with a wet rag. I assume running water over engine is a bad idea. Blowing air would get all over the interior.
This is the best shot I can get of the belt tensioner, just a little oil residue.
Old 04-03-2025, 06:04 PM
I washed my engine with some Purple Power and it came out great!
Sent from my SM-S938U using Tapatalk
Old 04-04-2025, 05:29 AM
the mileage isn't that high but the age is 10 years. so perhaps replace the belt?
Old 04-08-2025, 02:26 PM
Are you verifying that 060w-14 is in fact a date code? The belt looks near new.
The car has a 1 year old battery that is a Porsche brand, I'd assume the car was at a dealer for service in the last year.
Old 04-09-2025, 12:03 PM
The belt is the only wear item I can think of in the engine. Spark plugs come up at 40k.
I have no idea about belt date codes but you could inspect it for cracks if you dont have a receipt for the replacement.
Old 04-09-2025, 03:24 PM
There are no cracks in the belt. I may pull a spark plug to see how it looks. Do the 981’s need a special socket for the plugs like the 718’s?
Old 04-10-2025, 08:24 AM
