evan9eleven's Avatar
Boxster randomly dumps all washer fluid on garage floor...
As the title says, my 2004 Box S randomly dumps it's whole tank of washer fluid on the garage floor. In the 11 years I've had the car, this has probably happened 5 times. The car lives at my holiday home and as such it often sits for long periods. If I fill the washer fluid tank, it holds fluid with no problem, until all of a sudden the contents are on the floor, maybe months later... or not. Need some advice before I pull my front bumper.
Right front is where the puddle is, if that helps any.
1981 911SC restomod "Minerva"
2004 Boxster S
2021 Cayman GTS 4.0 manual "Olive"
2014 Cayenne GTS V8 (wife's lover)
The slope is not slippery; in fact it is entirely frictionless.
Old 02-03-2024, 12:41 AM
I think the tank is behind the wheel liner on drivers side.
Tony G
2000 Boxster S
Old 02-03-2024, 04:21 AM
Do you have headlight washers? Could be that.
The only other fluid in the right front is coolant.
Tony G
2000 Boxster S
Old 02-03-2024, 07:27 AM
That's a good thought. A YouTube video had one that leaked for Matt Armstrong and had to be replaced.
Sent from my SM-S928U using Tapatalk
Old 02-03-2024, 08:41 AM
Ding fing ding! We have a winner. Its the headlight washer. Looks like I'm overdue for a new pair of them.
2004 Boxster S
Old 02-03-2024, 09:03 AM
headlight washer replacement
FYI.. They can be easily replace by removing the headlight modules. No need to remove the bumper cover. But then you probably already figured that out.
Cheers.
71 911T Targa
Old 02-23-2024, 09:38 PM
